No Ringback on SIP trunk on outbound calls
I have a move from PRI to SIP. I can make calls connect and talk. The only gotcha is no ringback. I set the system parameter send H225 user info to Ann provides ringback. Still no luck. CUCM h225. HSRP will be setup once all is working, CUCM is 8.6 gateway 15.2
The big issue is it is a remote fix install and fix.,
I have attached the debugs.  It is unique way to this and not first choice but I suspect setting.
Any help even though there is not much data here,
Forgot call was made by
Forgot call was made by ASANKA
I am in the same situation,
I am in the same situation, did you resolve this ?
83
