No ringback over SIP
Hello guys,
I'm actually facing an issue in my IPTel network. When a PSTN user is calling us and if the call is transfered/forwareded he doesn't receive ringback.
Call flow:
PSTN --> SIP Gateway --> CUCM --> Phone 1 --> Forward/Transfer --> Phone 2
I checked the gateway and in each dial-peer pointing to the CUCM I have the command:
  - progress_ind setup enable 3
Under the sip configuration, I have a MRGL who contain an annonciator based on doc: http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-50/99341-ccm-sip-ringback.html
If someone has an idea...
Hervé Jacquemin
1 ACCEPTED SOLUTION
Try adding "voice call send
Try adding "voice call send-alert" to your CUCM dial-peers.  It's supposed to be able to convert a progress message with a progress indicator to an alerting message which should result in a 180 Ringing being sent to CUCM.  In that scenario, the phones would play the ringback themselves.
You might want to try
You might want to try enabling all of the codecs under the IPVMS service parameters if you haven't done so already.  Will probably need to see CallManager traces to see what is going on with the annunciator allocation.
Hello, Thanks for the answer,
Thanks for the answer, I checked and enable all the service but the problem is still there (maybe a service to restart to apply the change ??).
I will now go through the logs but which logs are the more specifics for the annunciator?
Hervé
Add this on CUBE/SIP gateway
Add this on CUBE/SIP gateway and then do a test...
sip
midcall-signaling passthru
Under the dial peer or
Just added the commands under "voice service voip" and did a test. Still the same :(
You can apply this either
You can apply this either under dial-peer or globally. voice service voip sip midcall-signaling passthru Or dial-peer voice xxx voip mid-call signaling passthru
did it globaly and still the
did it globaly and still the issue
Then please attach CUCM trace
Then please attach CUCM trace file. And do mention calling , called number with time of call. Thank Manish
time 9.58 amCaller id:
time 9.58 am
Caller id: 003227894364
Called id: 00496172408170
Forwad all number: 0032496529594
log files from 3890 - 3893 from publisher
log files frmo 2221 - 2225 from subscriber
Hello Hervé ,
Hello Hervé ,
Sorry for delay in reply .Your call flow is like this as per traces..
10.175.0.6 --> 10.161.10.170 --> 10.161.10.171 --->10.175.0.6
Now the call is going out from 10.161.10.171(SUB i guess) to 10.175.0.6 , then its a responsibility of SYST_CUCM2_ANN to provide ringback. But there is no annunciator is invoking in this call leg. Can you please recheck the MRGLs are they containing ANN ?
And one more thing , try setting up CFA to an internal number and then check the behavior.
rate all helpful post
Manish
Trunk has DEBHO_MRGLDEBHO
DEBHO_MRGL contains:
     - SYST_ANN_MRG
     - SYST_CFB_MRG
     - SYST_MTP_MRG
     - SYST_MOH_UNICAST_MRG
and then the SYST_ANN_MRG contains:
     - SYST_CUCM1_ANN
     - SYST_CUCM2_ANN
and both ANN are registerd.
I test this morning and it works fine if I forward to an internal number
And how about calling from an
And how about calling from an internal number to internal number , whose CFA is set to an outside number ? Thanks Manish
Internally there is no issue,
Internally there is no issue, it's just when an outside call is transfer/forwarded outside.
VIP Super Bronze
Please attach the sh run of
Please attach the sh run of your gateway
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
done :)
done :)
VIP Super Bronze
Pls remove this command from
Pls remove this command from your voip dial-peer (the dial-peers to cucm) and test again
still the sameI added this
still the same
I added this commande to test but with/without no changes.
Do I have to remove it from the pots dial-peer?
VIP Super Bronze
No, :et me look at your
No, :et me look at your traces and will reply shortly
VIP Super Bronze
OK...This trace is for a call
OK...
Based on the trace, we can see that when the call was forwarded, CUBE sends a 183 session progress with SDP. Now that suggests that the ISDN leg is playing some form of prompt instead of ring back...In this scenario when CUCN receives 183 with SDP, it doesn generate ringback locally, it just cuts through audio to try and play whatever the far end is playing..
We need to see the debug isdn q931, debug ccsip messages for this call.
Can you tell me if you get ringback for the following:
1. call forward all to an internal extension
2. Supervised transfer to an internal extension
3. blind transfer to an internal extension
4. normal calls
If all your test above work i.e you get ringback, then your issue is with your telco provider
I will take the traces right
I will take the traces right now.
regarding your question:
1: it's working
2: I'm not on site (I'm in Belgium, problem is in Deutschland) but normally it's working
3: it's working
4: it's working
attached the logs:Caller id:
attached the logs:
VIP Super Bronze
 Its just as I suggested, the
Its just as I suggested, the ITSP isnt playing ringback, but something else at the progress stage. You get the following prompt..once CUBE receives that it sends a session progress with SDP...for cucm to cut through to the audio your provider is playing. This is an issue on their end. Have a word with them.
#### At the progress stage (this is where we normarly get ringback, telco plays an announcement###
Mar 20 08:11:20.022: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0xAE8A
    Progress Ind i = 0x8288 - In-band info or appropriate now available
###CUBE sends PRACK for the early media, it received on the ISDN leg###
Sent:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 10.161.10.171:5060;branch=z9hG4bK1510b255d9c370
From: "Geschaftsleitung Konferenzraum" <sip:+496172408170@10.161.10.171>;tag=b07ad00f-590b-492b-beff-1db02e4d128f-20217387
To: <sip:0032496529594@10.175.0.6>;tag=692E7924-720
Date: Thu, 20 Mar 2014 08:11:15 GMT
Call-ID: 33ae1900-32a1a2a3-80f85-ab0aa10a@10.161.10.171
CSeq: 101 INVITE
Require: 100rel
RSeq: 2892
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: <sip:+32496529594@10.175.0.6>;party=called;screen=no;privacy=off
Contact: <sip:0032496529594@10.175.0.6:5060>
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 5181 6752 IN IP4 10.175.0.6
s=SIP Call
c=IN IP4 10.175.0.6
t=0 0
m=audio 29728 RTP/AVP 8 101
c=IN IP4 10.175.0.6
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
thanks a lot for your analyze
thanks a lot for your analyze ! I will have a look on this with the provider !
VIP Super Bronze
Brian,First of all this is
Brian,
First of all this is excellent information and well fone for giving us this tip. However this has its own major draw back. What this mean is that these users will never hear any announcement that the ITSP is sending them in cases where ITSP is playing an announcement. Because all progress message is now converted to 180 ringing, ringback will be played locally at all times.
That is correct.  Those
That is correct.  Those messages can definitely be important for troubleshooting with the carrier.  This will hopefully serve as a temporary workaround until he's able to determine why the carrier isn't sending the in-band ringback.
VIP Super Bronze
Hjacquem,Did you speak to
Hjacquem,
Did you speak to your provider? I know Brian's suggestion has worked for you, but you didnt rate my post!!! Have I offended you in anyway wink If I have here I am on bended knees..pls forgive melaugh
It'still ongoing with the
It'still ongoing with the provider :) I tried via email days ago, by phone, only in german it's not easy for me :D
I keep you inform as soon as I have a feedback !!
655
