03-02-2009 12:57 PM - edited 03-15-2019 04:34 PM
Hi All,
I have an H.323 gateway configured between my CallManager cluster and an Alcatel 4400 PBX. There are no routers involved, I am just pointing to the IP address of the Alcatel and visa versa.
Everything works OK apart from when I call an extension off the Alcatel; I do not hear ringtone on the CallManager handset. However the handset rings and when picked up, all works OK.
When a user on the Alcatel system calls a CallManager handset, ringtone is heard on the Alcatel and again all works OK.
Any assistance appreciated.
Colin
PS: CallManager 4.1(3)
Solved! Go to Solution.
03-02-2009 01:06 PM
Have you enabled "Media Termination Point" in the GW configuration page? Also try to enable "Inbound FastStart".
MK
03-02-2009 01:06 PM
MK
03-03-2009 01:19 AM
Hi Guys,
Many thanks for your assistance, I now get a ringtone with the following configuration;
1) Media Termination Point Required
2) Enable Outbound FastStart
3) Codec For Outbound FastStart: G711
Thanks also to Nick for pointing out the "Use ANN for Ringback" parameter, this is a new one on me!
Colin
03-02-2009 01:19 PM
Hi Colin,
I would suggest to try changing this service parameter:
Use H225 User Info -> Use ANN for Ringback
As well - make sure there is an annunciator in the default MRGL (the annunciator has not been applied to a MRG yet), otherwise confirm that the MRGL on the H323 gateway page has an available annunciator.
hth,
nick
