No RingbackTone on a Cisco IAD Gateway
I'm facing a problem with a Cisco Gateway IAD 2430.
This one runs the followings IOS : c2430-ik9o3s-mz.124-15.T17.bin
I'm looking for a way to play a ringback tone from this Gateway when a call is transferred by this device, because I don't hear any noise during 5 to 6 seconds until the first tone.
The blank consequence is Users end calls before waiting the whole blank period.
Here is current config (Real values below have been replaced by X):
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial1/0:X
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn send-alerting
no cdp enable
dial-peer voice X pots
destination-pattern .T
no digit-strip
port 1/0:X
dial-peer voice XXX voip
voice-class codec 1
session protocol sipv2
session target ipv4:X.X.X.X:5060
session transport udp
incoming called-number XXX$
Thanks in advance for your help.
Fabrice
1 REPLY
Can you add the full config?
Do you have already try this command?
sip-ua
disable-early-media 180
Add also a debug ccsip message.
Regards.
149
