No-Route Destination on Cisco 5400 with Cisco PGW 2200
Dear Sir,
let me first expalin my scenario here :
My call is coming from PSTN on pots and landed on media gateway Cisco 5400 with signalling on Cisco PGW 2200 and then cisco forward it to Softswitch on voip dialpeer.
Now issue is that when i tried for example 30 attempts, then out of 30 two attempts lost.
My softswitch didnt receive these two attempts and cisco failed the calls from no route to destination. when i traced these calls from PGW, then i came to know that its not forwarded to Softswitch.
PGW trace is attached and also the debug trace of 5400 is also attached .
Configs of dialpeers are as follows :
dial-peer voice 1001 voip
description Towards Advanced VOIP
translation-profile outgoing national
huntstop
destination-pattern .T
voice-class codec 2001
session protocol sipv2
session target ipv4:xxx
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 9600
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 3710 pots
tone ringback alert-no-PI
description ### FOR ORIGINATION POTS DIALPEER###
translation-profile incoming Remove-C
direct-inward-dial
port 6/2:D
dial-peer voice 3730 pots
description ### FOR ORIGINATION POTS DIALPEER ###
translation-profile outgoing national-outgoing
destination-pattern 92102T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 6/0:D
voice translation-profile Remove-C
translate called 1450
voice translation-profile national
translate calling 1000
translate called 1550
voice translation-profile national-outgoing
translate calling 1700
translate called 1000
voice translation-rule 1000
rule 1 // // type any national plan any isdn
voice translation-rule 1450
rule 1 /C/ //
voice translation-rule 1550
rule 1 /^1947100/ /1947/
rule 2 /^\(1947\)\(.*\)$/ /194700\2/ type international international plan any isdn
voice translation-rule 1700
Can you please guide where and why these two attempts are missing?
Bilal
Everyone's tags (5)
302
