No tone during a call on FXO port on CCME
When I a made a call with a ip phone to the fxo port, i get no call tone, but the "other side" phone rings and can hang up.
During a call, there is only one way voice, the phone on the public voice network "can listen" and the local phone "can talk" but no "listen".
Config on the router:
voice-card 0
voice-port 0/0/1
compand-type a-law
cptone ES
impedance complex2
dial-peer voice 1 pots
description Trucades entrants
destination-pattern 0T
incoming called-number .
port 0/0/1
regards
Hall of Fame Super Gold
Re: No tone during a call on FXO port on CCME
Are the the IP phones working normally ?
Which IOS version are you using ?
Yes, the 7906 IP phones are working normally and the ios version is c2801-advipservicesk9-mz.124-9.T3, downgraded from the 12.4.11T1 because if there are any unknow bug..
This router also have a cbac and site to site vpn implemented with an adsl wic...
Finally it works!, I have to disable the cbac firewall and access-list because it seems to block voice trafic from the ip phone to de FXO port...(??).
Is this a bug or a bad configuration?
102
