No voice calls TX -> CONNECT sent after rtp stream establish
Hello Guys,
I have a strange behavior on the IPTel network of one of my customer. Sometimes (1-2 times a week) the customer had a faulty calls. When he received an incoming calls, he heard nothing. The callers sometimes heard somethings (not each time).
I enable a lot of logs on the gateway and I found the following:
The RTP stream is established only in one way but the:
36620774: Oct  3 08:34:49.464: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8345
Is sent after the RTP stream is ended (stream has a duration of 5 sec), when the caller/called hang off.
Normally the "TX -> CONNECT" is sent before the RTP stream establishement.
I attached the complete call flow. I change the phone number:
Caller ID is:YYYYYYYYYY
Called ID is: XXXXXXXXXX
Internal extension: 811
Thanks a lot for your help !
Hervé Jacquemin
1 REPLY
Re: No voice calls TX -> CONNECT sent after rtp stream establis
Your gateway doesn't send the ACK in response of received 200OK. Try to disable PRACK.
Could be not correctly handled.
Sent:
INVITE sip:811@192.168.150.3:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.150.2:5060;branch=z9hG4bK1E8EAF0
Call-ID: AF63FA16-2B2C11E3-992DD659-40589DE0@192.168.150.2
CSeq: 101 INVITE
Received:
SIP/2.0 100 Trying (concerned to INVITE)
CSeq: 101 INVITE
Received:
SIP/2.0 180 Ringing (concerned to INVITE)
CSeq: 101 INVITE
Sent:
PRACK sip:811@192.168.150.3:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.150.2:5060;branch=z9hG4bK1E8F9A1
CSeq: 102 PRACK
Received:
SIP/2.0 200 OK (concerned to PRACK)
CSeq: 102 PRACK
Received:
SIP/2.0 200 OK (concerned to INVITE)
CSeq: 101 INVITE
Sent:
ACK sip:811@192.168.150.3:5060;transport=tcp SIP/2.0  (concerned to PRACK)
Via: SIP/2.0/TCP 192.168.150.2:5060;branch=z9hG4bK1E906A1
CSeq: 101 ACK
Received:
CSeq: 101 INVITE
Received:
CSeq: 101 INVITE
Sent:
CSeq: 101 ACK
Sent:
CSeq: 101 ACK
Received:
CSeq: 101 INVITE
200 ok timeout
Regards.
206
