No voice-port 2821 w/HWIC-1CE1T1-PRI and PVDM2-32
I am in the middle of setting up a voice gateway and when I try to set up the voice-port, I get "Invalid input".
Applicable config:
controller T1 0/0/0
framing esf
linecode b8zs
cablelength short 110
pri-group timeslots 1-24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-dms100
isdn incoming-voice voice
isdn map address . plan isdn type national
isdn send-alerting
isdn outgoing ie redirecting-number
isdn outgoing ie high-layer-compat
isdn outgoing ie user-user
no cdp enable
Show inventory output:
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V04 , SN: FTX1222A0N3
NAME: "1 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 0", DESCR: "1 port channelized and PRI T1/E1 HWIC"
PID: HWIC-1CE1T1-PRI , VID: V01 , SN: FOC12043N5W
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32 , VID: V01 , SN: FOC12161HE7
I've been trying to figure this out and I've hit a brick wall. I thought I had all the pieces...
Thank you
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: No voice-port 2821 w/HWIC-1CE1T1-PRI and PVDM2-32
Hi Richard,
The problem here is that the HWIC-1CE1T1-PRI does not support Voice PRI's. :( You will want to use a VWIC.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html
Hope this helps! Sorry man,
Rob
Hall of Fame Super Gold
Show ver? You might be running an image w/o voice support. E.g. ipbase.
Hi Richard,
Rob
Oh, I misread that, I "wanted" to read VWIC and so I did :[
Of course Rob is correct. So 5 points for him here.
Hi Paolo,
You are most kind! Thanks for this nice vote my friend.
Rock On!
Huff
Wow, thank you. Not great news but I figured there had to be a good reason.
Thank you all,
Richard
584
