no voice port on CME
I am trying to assist my uncle with setup of a PRI on their CME router.  I've created the pri-group and I can see the channels are good and the call comes in, but always end in fast busy.  I do not see the voice-port populating after created the pri-group.  I'm stumped on why the voice port is not created for setting bearer cap.
I am expecting to see a section of my running-config, but it does not come up:
voice-port 0/3/0:23
  bearer-cap speech
sh isdn stat
Global ISDN Switchtype = primary-ni
ISDN Serial0/3/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x800003FF
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 0
sh isdn serv
PRI Channel Statistics:
ISDN Se0/3/0:23, Channel [1-24]
  Configured Isdn Interface (dsl) 0
   Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
    Channel :  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
    State   :  0 0 0 0 0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 3 3 3 3 3
   Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
    State   :  0 0 0 0 0 0 0 0 0 0 2 2 2 2 2 2 2 2 2 2 2 2 2 2
Here are my first results:
chrs-phx-cme#
Dec 11 05:48:03.655: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0DAA
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Facility i = 0x9F8B0100A10D02010102010080055445584153
                Protocol Profile =  Networking Extensions
                0xA10D02010102010080055445584153
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = TEXAS
        Calling Party Number i = 0x2180, 'xxxxxx9001'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, 'xxxxxx5159'
Dec 11 05:48:03.655: ISDN Se0/3/0:23 Q931: Received SETUP  callref = 0x8DAA callID = 0x0411 switch = primary-ni interfac
e = User
Dec 11 05:48:03.655: ISDN Se0/3/0:23 **ERROR**: accept_incoming_csm_call: modem problem Bearer capability not available(
0x3A): b channel 0, call id 0x411
Dec 11 05:48:03.659: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8DAA
        Channel ID i = 0xA98381
                Exclusive, Channel 1
Dec 11 05:48:03.659: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8DAA
        Cause i = 0x80BA - Bearer capability not available
chrs-phx-cme#
Dec 11 05:48:03.679: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0DAA
Dec 11 05:48:03.679: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8DAA
chrs-phx-cme#
In CME I added the 5159 to a user as the Primary E.164 Number, and that gave me the following result:
Dec 11 06:08:13.919: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0DBA
                Standard = CCITT
                        Invoke Id = 1
                                Name = TEXAS
        Called Party Number
chrs-phx-cme# i = 0xA1, 'xxxxxx5159'
Dec 11 06:08:13.919: ISDN Se0/3/0:23 Q931: Received SETUP  callref = 0x8DBA callID = 0x0002 switch = primary-ni interfac
e = User
Dec 11 06:08:13.919: ISDN Se0/3/0:23 **ERROR**: call_incoming: Received a call id 0x2 with a bad bearercap from 91552690
01 on b channel 1
Dec 11 06:08:13.923: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8DBA
        Cause i = 0x80C1 - Bearer capability not implemented
chrs-phx-cme#
Here are the basics:
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
NAME: "1 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 3", DESCR: "1 port channelized and PRI T1/E1 HWIC"
PID: HWIC-1CE1T1-PRI   , VID: V02 ,
Running Config:
card type t1 0 3
logging buffered 300000
no aaa new-model
clock timezone ARIZONA -7 0
no network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip name-server 192.168.0.2
no ipv6 cef
stcapp ccm-group 2
stcapp supplementary-services
port 0/2/0
  fallback-dn 121
isdn switch-type primary-ni
trunk group 1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class custom-cptone leavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone jointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice translation-rule 1
rule 1 /1../ /xxxxxxxxxx/
voice translation-profile outgoing
translate calling 1
voice-card 0
dsp services dspfarm
controller T1 0/3/0
clock source internal
cablelength long 0db
pri-group timeslots 1-10,24
ip ssh version 2
interface Serial0/3/0:23
no ip address
encapsulation hdlc
no cdp enable
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/1
service-module ip address 192.168.0.9 255.255.255.0
service-module ip default-gateway 192.168.0.2
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 0.0.0.0 0.0.0.0 192.168.0.2
ip route 192.168.0.9 255.255.255.255 Service-Engine1/0
control-plane
voice-port 0/0/0
trunk-group 1
connection plar 774
description 602.246.7607
caller-id enable
voice-port 0/0/1
trunk-group 1
connection plar 774
description 602.246.0310
caller-id enable
voice-port 0/0/2
trunk-group 1
connection plar 774
description 602.246.0954
caller-id enable
voice-port 0/0/3
trunk-group 1
connection plar 774
description 602.277.4233
caller-id enable
voice-port 0/1/0
trunk-group 1
connection plar 774
shutdown
description 602.264.1518
caller-id enable
voice-port 0/1/1
trunk-group 1
connection plar 774
shutdown
description 602.264.1705
caller-id enable
voice-port 0/1/2
timeouts call-disconnect 3
shutdown
caller-id enable
voice-port 0/1/3
no battery-reversal
shutdown
voice-port 0/2/0
timeouts ringing infinity
description Bogen Paging Adapter
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 192.168.0.8 identifier 100 priority 1 version 4.1
sccp
sccp ccm group 2
bind interface GigabitEthernet0/1
associate ccm 100 priority 1
associate profile 2 register DSPprofile2
keepalive retries 5
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
shutdown
dial-peer voice 10 voip
destination-pattern 778
session protocol sipv2
session target ipv4:192.168.0.9
codec g711ulaw
no vad
dial-peer voice 11 voip
destination-pattern 779
codec g711ulaw
no vad
dial-peer voice 777 voip
description Cisco Unity Express voicemail pilot number
destination-pattern 777
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 776 voip
description Cisco Unity AA
destination-pattern 776
codec g711ulaw
no vad
dial-peer voice 775 voip
description Cisco Unity AA-admin
destination-pattern 775
codec g711ulaw
no vad
dial-peer voice 9 pots
trunkgroup 1
description PRI
destination-pattern 9T
no sip-register
dial-peer voice 443 pots
destination-pattern 443
port 0/1/3
forward-digits 0
dial-peer voice 444 pots
service stcapp
port 0/2/0
card type t1 0 3
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
stcapp ccm-group 2
port 0/2/0
  fallback-dn 121
trunk group 1
voice service voip
dualtone conference
  frequency 400 800
dualtone conference
  frequency 600 900
translate calling 1
voice-card 0
controller T1 0/3/0
ip ssh version 2
no ip address
encapsulation hdlc
no cdp enable
ip http server
ip http path flash:
control-plane
voice-port 0/0/0
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/0/1
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/0/2
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/0/3
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/1/0
trunk-group 1
connection plar 774
shutdown
caller-id enable
voice-port 0/1/1
trunk-group 1
connection plar 774
shutdown
caller-id enable
voice-port 0/1/2
shutdown
caller-id enable
voice-port 0/1/3
no battery-reversal
shutdown
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
sccp
sccp ccm group 2
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
shutdown
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
trunkgroup 1
description PRI
no sip-register
port 0/1/3
forward-digits 0
service stcapp
port 0/2/0
!3/0
1 ACCEPTED SOLUTION
I think HWIC is not supported for voice..its only for data...
Check this out...
https://supportforums.cisco.com/thread/2118228
Pls rate if it helps
Ajay
Configure the "isdn incoming-voice voice"  under the serial interface.
Ajay
I found that shortly after my post, no change.  I shut/no shut and I even reloaded the CME.  Other ideas?
chrs-phx-cme#sh run int serial 0/3/0:23
Building configuration...
Current configuration : 138 bytes
no ip address
encapsulation hdlc
no cdp enable
end
chrs-phx-cme#sh run | sec voice-port
voice-port 0/0/0
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/0/1
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/0/2
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/0/3
trunk-group 1
connection plar 774
caller-id enable
voice-port 0/1/0
trunk-group 1
connection plar 774
shutdown
caller-id enable
voice-port 0/1/1
trunk-group 1
connection plar 774
shutdown
caller-id enable
voice-port 0/1/2
shutdown
caller-id enable
voice-port 0/1/3
no battery-reversal
shutdown
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
chrs-phx-cme#
I don't find any dial peer for port 0/3/0:23. Can post the dp configs
Ajay
Can I have a dial-peer without the associated voice-port existing?
chrs-phx-cme#sh run | sec dial-peer
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
trunkgroup 1
description PRI
no sip-register
port 0/1/3
forward-digits 0
service stcapp
port 0/2/0
chrs-phx-cme#
You need to have an inbound dial peer for to match the inbound call leg.
Ajay
Still inbound fast busy.
dial-peer voice 5 pots
description inbound PRI DP
destination-pattern .
no sip-register
Dec 11 07:17:40.091: ISDN Se0/3/0:23 Q931: Received SETUP  callref = 0x8DD9 call
ID = 0x0014 switch = primary-ni interface = User
Dec 11 07:17:40.091: ISDN Se0/3/0:23 **ERROR**: accept_incoming_csm_call: modem
problem Bearer capability not available(0x3A): b channel 0, call id 0x14
Try this
port 0/3/0:23
no sip-register
else
incoming called-number .
direct-inward-dial --(if did)
No help, port 0/3/0:23 does not exist.
Dec 11 07:43:54.495: ISDN Se0/3/0:23 Q931: Received SETUP  callref = 0x8DE4 call
ID = 0x001F switch = primary-ni interface = User
Dec 11 07:43:54.499: ISDN Se0/3/0:23 **ERROR**: accept_incoming_csm_call: modem
problem Bearer capability not available(0x3A): b channel 0, call id 0x1F
Dec 11 07:43:54.499: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
DE4
Dec 11 07:43:54.499: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
8DE4
chrs-phx-cme(config-dial-peer)#
Unless someone can tell me otherwise, I think the problem is the card?
HWIC-1CE1T1-PRI - this is for data only, not voice?
Jason
Check this out...
Ajay
510
