Bronze
Noisy FXO Port
I have a 2621XM with a NM-2V and a VIC-2FXO. Any incoming or outgoing calls on 1 of the FXO ports always seems to have a hum or buzz in the background. I swapped the analog lines going into the FXO ports and the hum or buzz seems to follow the FXO port. I'm assuming it's a hardware problem? Has anyone seen this before? Thanks!!
Hall of Fame Super Red
Re: Noisy FXO Port
Hi Mike,
It certainly sounds like a hardware issue. The "rule of thumb" for troubleshooting this type of problem has always been to do what you have done. Move the line, if the trouble follows the line, it's a noisy line. If the trouble stays with the port it's a probable hardware issue. The only other variables are, the line cords and perhaps, removing re-seating the module.
Take care,
Rob
Silver
Re: Noisy FXO Port
I have a similar issue.
All FXO's have a hum, one of the lines has some static when talking only. checked the lines at the panel and test ok. changed FXO card and problem is still there.
what fixed your issue?
Hall of Fame Super Gold
Re: Noisy FXO Port
Being the original an old message, likely you won't get a reply. Please follow the procedure indicated in my reply to your other message.
Bronze
Re: Noisy FXO Port
It was a bad card. I replaced the card and it was fine after that.
287
