Nokia E-series VPN conecction to CCM
I want to connect an E65 and E61i mobile phone through an Internet Wi-Fi conecction.
I listened in a conference that Nokia phone can create a VPN conecction against a terminal VPN equipment in a network and obtain an inside thelephone number from CCM (in this case an UC500). In that way Nokia phone could work as an internal phone wherever these are in any location around the world.
How can I implement this solution?
I did not find a document about this solution in cisco web page.
Bronze
Re: Nokia E-series VPN conecction to CCM
I suggest you to forget mobile VPN with E65 and E61i. There are some issues with Nokia S60 3.0 and mVPN.
With Nokia S60 3.1 mVPN is working pretty good with some restrictions. You can find more information from here: http://www.businesssoftware.nokia.com/mobile_vpn_downloads.php
What comes to telephone solution you should check Nokia Call Connect for Cisco client. It enables IP over WLAN business voice communications integration with Cisco Unified Communications Manager and Unified Communications Manager Express/UC500. More information from here: http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
-Pasi-
Pasi is almost right :)
I have E65 and as commented here in this google group http://groups.google.de/group/comp.dcom.sys.cisco/browse_thread/thread/86139e1a50ddfec9 it is possible to install your VPN Policy on E65 as well. After I succeeded, then I use Call Connect for Cisco client to connect to the CM and successfully have IP Phone from anywhere in the world through the VPN.
It is way too easier to get it working with E90, E66 and so on (S60 3rd Edition Feature Pack 1 or newer)
269
