Nokia E55 no button
Hi to all,
I have a UC520 with last IOS with CME 7.0  version, try to configure a Nokia E55 as internal device using Nokia CC Cisco, in UC520 I configure aephone like this:
telephony-service
load 7970 SCCP70.8-5-3S
ephone  11
device-security-mode none
description Nokia E55
mac-address XXXX.XXXX.XXXX
after-hours exempt
username "user" password user
codec g729r8
type 7970
button  1:10
all seem works fine, the registrer regular, but CME does not assign the button, so is then is not possible to use the device, because there not a line assigned.
UC520#sh ephone reg | begin ephone-11
ephone-11[10] Mac:XXXX.XXXX.XXXX TCP socket:[9] activeLine:0 REGISTERED in SCCP ver 5/5
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:3
IP:192.168.10.16 44362 Unknown 376  keepalive 2 max_line 0
Preferred Codec: g729
Username: user Password: user
after-hour exempt
Any body have any idea or suggestion? Why it occurs?
Than you very much.
Augusto
1 REPLY
Re: Nokia E55 no button
Hello Augusto!
Which version of Nokia CC Cisco you are using? v1.1 or v2.0?
Pavel
173
