Nokia E61 Cisco client
Hey
is there a way to add some dialling rules so that when the phone is on WIFI it will automatically prefix the dialled number with 0 ( or whatever the button is for external line in the CME )?
Currently I have to dial one way when I m on GSM and another way when I am on WIFI and it means I cannot transparently use the features as I want, i,e it is to easy to forget to dial leading 0 once on WIFI.
Any hints much appreciated.
Re: Nokia E61 Cisco client
Hi there,
Has anyone found a solution for this yet?
We are dealing with the same problem.
Thanks for your reply.
Gr,
Jasper
DOES CISCO CALLMANAGER 4.1 support this feature?
Yes it was quite easy actually, just add a dial-peer with a COS that makes your intellisynch only see this dial-peer and have it automatically prefix the 0 and then it just works.
above is for ucme if you use ucm you can achieve the same with search spaces etc.
215
