Community Member
Nokia E90 with CCM 6.x
hii, please i have a cisco callmanager 6.0 and a nokia phone E90, i want to intregrate it to the ccm via wifi, i don't have any idea to this configuration in ccm...
Hall of Fame Super Gold
Re: Nokia E90 with CCM 6.x
Hi, have you purchased the necessary software "intellisync 1.1" from either Cisco or Nokia?
Community Member
hi, thanks for the information, but i wanna know if there some configuration to add on the CCM, like "add phone?" Thanks
Yes, you would add a phone.
Unfortunately without the software above mentioned, it cannot be made to work.
Community Member
hii, i have installed the software in the Nokia phone, but in the ccm what is the type of the phone to use, in the "add new phone"?
136
