Nokia Intellisync 1.1
Anyone is able to run Nokia Intellisync 1.1 on Nokia Eseries and register the phone on CallManager?
Re: Nokia Intellisync 1.1
I solved the issue: the SCCP phone on Cisco CallManager for 1.1 must be a 7970 and not 7960 as for 1.0.
According to the Nokia user guide/release notes, it mentions Callmanager should be configured as a S60 (plugin necessary for Callmanager) and for Callmanager express versions it should be configured as a 7970.
Could you give me the link where i can download the 1.1 release notes and CallManager plugin?
On Nokia site i can find only Intellisync 1.0 user guide and release notes.
Stefano
Bronze
anyone ever got the E series working with just the SIP client?
Hi Arvind,
I had this confirmed by Cisco that this doesn't work, the only way to get the Nokia phones working was with the Client
I hope this helps
Dave
Nokia E65 and E61i works in SIP on CCM and CCME while E61 doesn't work.
Stefano
Bronze
guys,
someone previous posted a config to get this working.Thread - http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddedac9/8#selected_message
i never did get it working using SIP.
Anderson i know you said the SIP would not work but im hearing mixed opinions.
anyone have a clear answer and/or config to get this working with teh SIP client?
thanks in advance
I can confirm The build in SIP client is working on the Nokia E60, E61 and E90 using CUCM 6. Possibly on other eseries devices as well but I have only tested these 3.
These are the settings needed on the Nokia device :
Profile name: CUCM6
Service Profile: IETF
Default Access point: *your wifi access point*
Public user name: sip:1000@172.16.10.105 <= (your extension@your server address)
Use compression: No
Registration: On demand or Always on
Use security: No
Proxy server
Proxy server address: sip:172.16.10.105 < = (host name CUCM SIP Realm CFG)
Realm: CUC6009941 < = (host name CUCM SIP Realm CFG)
User name: 1000 <= ( your extension, configured in SIP Realm user name)
Password: *your password* <= ( configured in SIP Realm pwd)
Allow loose routing: Yes
Transport Type: UDP
Port:5065
Registrar Server
Registrat serv. addr.: sip:172.16.10.105 < = (host name CUCM SIP Realm CFG)
Transport Type: UDP
Port:5060
CUCM6 CFG
SIP Realm
Realm: CUC6009941
user: 1000
pwd: password
End User Configuration:
UserID=1000
Digest Credentials=password
insert device based on MAC
3rd party basic sip phone
assosiate device
System - Security Profile - Phone Security Profile
Third-party SIP Device (Advanced) - Standard SIP Non-Secure Profile
Third-party SIP Device (Standard) - Standard SIP Non-Secure Profile
enable Enable Digest Authentication and set transport type
security template enable Digest Credentials
Create a new SIP Profile "NOKIA E61 Standard SIP Profile" allowing you to change specific settings
System - Enterprise Parameters: change parameter " ccmsipline" to "CUC6009941" & auto registration from SCCP to SIP
Kind Regards,
Jeroen
Bronze
thanks for the great info. However, you said version 6, we have version 5.1.2(b) currently and was under the impression that it would have worked with this as well.
Note*** Not seeing ccmsipline parameter under ent param.
thanks again
Hi Jeroen
I am configuring SIP Phone in NOKIA E90 with CCM 6.0. When I add a new Sip Profile, I encounter an error : "Profiles in same realm must have same user name" in NOKIA E90. I checked user name. Everything is OK. I can't save this profile.
Can you tell me the solution for this issue?
Thanks.
When working with the build in sip client on the Nokia, it is always best to have only 1 profile defined.
So, try and delete all the existing ones you have and only add the one you will use for CCM 6
Rgds,
Jeroen
I configured the Nokia CallConnect 1.37 SCCP client with CME 3.3. This worked fine, but when I configured the same DN in other IP Phone ( Shared Line) , I call the DN, but only ringing the Nokia or the IP Phone, but not both...
Someone have tested this?
Ivan Garrido
ivan.garrido@la.logicalis.com
Hall of Fame Super Gold
Ivan, send config please ?
I attach the config, the ephone 11(7940) and ephone 22(Nokia) sharing line 105.
Ivan
interface FastEthernet0/0.20
description Gateway Voz
encapsulation dot1Q 20
--More-- ip address 10.56.1.1 255.255.255.0
h323-gateway voip bind srcaddr 10.56.1.1
tftp-server flash:P00403020214.bin
tftp-server flash:CP7912060000SCCP050124A.sbin
tftp-server flash:apps11.1-0-0-72.sbn
tftp-server flash:cnu11.3-0-0-81.sbn
tftp-server flash:cvm11.7-2-0-66.sbn
tftp-server flash:dsp11.1-0-0-73.sbn
tftp-server flash:jar11.7-2-0-66.sbn
tftp-server flash:SCCP11.7-2-1-0S.loads
tftp-server flash:term11.default.loads
control-plane
voice-port 0/0/0
station-id name FAX CHILE
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 540 voip
tone ringback alert-no-PI
destination-pattern *5T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
modem passthrough nse codec g711ulaw
session target ipv4:10.1.100.239
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 541 voip
--More-- tone ringback alert-no-PI
preference 2
session target ipv4:10.1.100.238
no vad
telephony-service
max-ephones 30
max-dn 30
ip source-address 10.56.1.1 port 2000
auto assign 1 to 30
system message LOGICALIS - CHILE
url services http://10.56.0.8/services.asp
user-locale ES
time-zone 18
time-format 24
create cnf-files version-stamp 7960 Jan 11 2008 09:48:07
max-conferences 4 gain -6
web admin system name softnet password softnet
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 1..
transfer-pattern *54...
transfer-pattern *.....
transfer-pattern *......
xmlschema grabacion
--More-- !
ephone-template 1
ephone-dn 11 dual-line
number 105
name CISTERNAS, Pedro
ephone-dn 22 dual-line
number 105
label Nokia E61
description telefono en prueba
name Nokia E61
ephone 11
mac-address 000E.8492.D528
type 7940
button 1:11
ephone 22
description prueba NOKIA
mac-address 0019.790F.AC84
type 7960
button 1:22
line con 0
line aux 0
line vty 0 4
access-class 2 in
privilege level 15
transport input ssh
line vty 5 15
access-class 2 in
privilege level 15
transport input ssh
scheduler allocate 20000 1000
ntp master 1
end
RT-Softnet#
RT-Softnet#sh tele
RT-Softnet#sh telephony-service
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
max-ephones 30
max-dn 30
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
user-locale ES
time-format 24
date-format mm-dd-yy
timezone 18 SA Eastern Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
auto assign 1 to 30
local directory service: enabled.
xml schema grabacion
you cut the configuration due to "more". So I don't see two ephones both with button 1:22 as expected.
Thank you!!
I configured both ephone with button 1:11 and now the sharing line is working fine!!
My mistake was to configure both ephone with diferents button (1:11 and 1:22), but the same number in both button.
Thanks a lot.
Ivan.
242
