Nokia phones integration with comunications manager / CME
Does any of you have a reference (link) about the procedure of how to integrate Nokia phones.
the admin guide does not include anything about this issue.
Hall of Fame Super Red
Re: Nokia phones integration with comunications manager / CME
Hi Filiberto,
The Nokia E Series is currently supported;
Supported Nokia mobile devices:
Nokia E51
Nokia E60 (PR3)
Nokia E61 (PR3)
Nokia E61i
Nokia E65
Nokia client software:
Cisco Unified Communications
Manager 6.x
Manager 5.x
Manager 4.2
Manager 4.1x
Manager Express 4.1
500 Series for Small Business
From this good Nokia doc;
http://europe.nokia.com/NOKIA_BUSINESS_26/Europe/Products/Mobile_Software/Cisco_CallManager/cisco_datasheet.pdf
The support docs and software can be found here;
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
Hope this helps!
Rob
Bronze
It seems that that document is not so up to date anymore.
Supported devices are:
Nokia E51 100.34.20 or later
Nokia E51-2 151.34.20 or later
Nokia E60 3.0633.09.04
Nokia E61 3.0633.09.04
Nokia E70 3.0633.09.04
Nokia E61i 2.0633.65.01 or later
Nokia E65 2.0633.65.01 or later
Nokia E66
Nokia E71
Nokia E90 200.34.73 or later
Br,
-Pasi-
Hi Pasi,
Where did you get this list from? can you confirm it?
I have had a look under the handset spec for the various Nokias, there is WiFi support on all of the E-series, but in Robs post there is WiFi and VoIP over WLAN for the devices he mentions. I can't see this under the likes of the E66 and E71.
I'm desperate to go buy a handset and set it up today but unsure on the correct device!
Any advice appeciated.
Stafford
Bronze
Stafford,
The list is from here:
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco/files/RelNotes_ICC_Cisco_1_1_2_US.pdf
I can confirm I have used an E61i on CUCM 6.0. According to Nokia, the CallConnect software that is loaded on the handset (their version of an SCCP client), is supported on the E66 and E71. If you but one of these handsets, go to the Download! option on the phone and select the Internet folder. Then download the Nokia ICC Cisco package. This will load the softare onto your phone. I had to do this with the E61i, not sure if the E66/E71 have it pre-loaded or if you need to follow the same steps. From there I just added it as a 7970 phone on the CUCM and it works great! Anymore questions let me know.
-Mike
http://cs-mars.blogspot.com
Bronze
Yep. List is from the release notes.
SCCP client is not pre-loaded to any of the devices. If you don't want to use Download! service you can always install the client with PC suite.
Remember to activate licence after installation.
-Pasi-
Hi Rob,
I have already checked the links, very good reference. However most of them refers to comunications manager, what about communications manager express?
There is no difference regarding the intellisync Call Connect when I use CME?
Thanks a lot for your time
Hi Filiberto,
If you want to register the phone via SIP to your CME, the following link has a very usefull example:
http://uc-b.blogspot.com/2008/04/opening-post.html
I have a Nokia N-95 and I registered in UC-500 (CME) and worked fine.
Hi angel
I'm following your guide in order to register a N95 in CME 4.0.
In my scenario, I don't have SIP-PROXY
which options from sip setting should I discard?
Attached is the config that I used.
I used a UC-500, but UC-500 run CME.
582
