Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Nokia phones running VoIP Settings version 3.x CUCM 6
Hi!
Is there any way to get Nokia phones running VoIP Settings version 3.x to work with Cisco Callmanager CUCM 6?
Since Nokia changed their SIP information it now writes a randomly translated username in the contact URI, i.e. aweofj293j2c0239jdwiofje0@nataddress instead of username@nataddress, which it did prior to version 3.x.
Incoming calls works fine, however for outgoing calls there´s only one way audio. Audio works from sip to pstn, but not from pstn to sip.
CUCM 7.x supports this.
This is a big issue with customers running CUCM version 6.x. It´s difficult to justify an upgrade to version 7.x just to get support for newer Nokia phones.
Is there any good third-party SIP client out there, that doesn´t require a logon to a different sip-provider, it doesn´t have to be free.
Any help appreciated.
Regards Marenl01
288
