Non-Existing Number return to internal Extension
Call Flow:
IPPHONE--> CUCM-->VG-->ISP
Signaling path : SIP
If we dial a  number that is not exist and the three last digits are the same with our extensions then the call is not  drop down but its coming back to the extension with the same three last digits
Example:
calling 92234567 and this number does not exist then the call reach our extension with number 567
Can we fix that or the ISP must change something about that
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Could you provide the telephony related configuration from the voice gateway as well as output of "debug ccsip messages" for a call?
Kind regards, Andrew C.
Do you have dial-peers for such DNs (567) in your GW???
And what do you send to telco??
Any translation rules?
It might be your configuration which is sending the calls back in.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: Non-Existing Number return to internal Extension
No I dont have a dial peer pointed to this destination.its ... the destination number into dial peer
I dont have a  translation rule into the cucm
voice translation-rule 1
rule 1 /22210362/ /295/
rule 2 /22755656/ /295/
rule 3 /22751555/ /218/
rule 4 /22466425/ /161/
rule 5 /22473000/ /295/
rule 6 /22473001/ /201/
rule 7 /22473009/ /295/
rule 8 /22473011/ /295/
rule 9 /22473013/ /295/
rule 10 /25255550/ /295/
rule 11 /25255552/ /295/
voice translation-rule 3
rule 2 /^9/ //
voice translation-rule 4
rule 1 /\+/ /900/
rule 2 /^\(9\)\(.......$\)/ /99\2/
rule 3 /^\(2\)\(.......$\)/ /92\2/
rule 4 /^0/ /90/
rule 5 /^1/ /9001/
rule 6 /^3/ /9003/
rule 7 /^4/ /9004/
rule 8 /^5/ /9005/
rule 9 /^6/ /9006/
rule 10 /^7/ /9007/
rule 11 /^8/ /9008/
rule 12 /^9/ /9009/
rule 13 /^2/ /9002/
voice translation-rule 5
rule 1 /^9/ //
voice translation-profile Profile-CYTA-to-CM
translate calling 4
translate called 1
voice translation-profile SIP_Outgoing
translate calling 5
translate called 5
dial-peer voice 888 voip
description **SIP Trunk to CYTA OUTGOING**
translation-profile outgoing SIP_Outgoing
destination-pattern 9T
session protocol sipv2
session target sip-server
voice-class codec 2
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 889 voip
description **Incoming calls From ISP*
incoming called-number .
voice-class codec 2
no voice-class sip outbound-proxy
dtmf-relay rtp-nte
no vad
dial-peer voice 900 voip
description **SIP Trunk to CUCM1**
translation-profile outgoing Profile-CYTA-to-CM
destination-pattern ...
session target ipv4:192.168.1.202:5060
voice-class codec 2
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
no vad
dial-peer voice 910 voip
description **SIP Trunk to CUCM2**
session target ipv4:192.168.1.203:5060
voice-class codec 2
dtmf-relay rtp-nte
no vad
Chrysostomos
Below is the debug for one non-existing number
You can see that the ISP return the 404 not found but the cube then send an ACK and then re-invite to the cucm
With result the call finall instead to drop down to reach one extension into CUCM
Attached is the debug
I have not read the debug you enclosed yet, but I can say that you should change the configuration of the dial-peers number 900 and 910. You should change your destination-pattern from '...' to something more specific and add $ to the end to disable variable-length matching (this could be the root of your problem, btw). So your final destination-pattern should be something like this:
destination-pattern 3..$
Please try it and reply with results.
Kind regards,
Andrew C.
With change the destination-pattern ... to [1-2].. then fixed teh issue
Chrysostomos
255
