07-05-2009 05:11 AM - edited 03-18-2019 10:26 AM
I need after office hrs no body should be able to make any types of outbound calls like Local, Mobile/International where as only Inbound calling should work..Is there any way to achieve this??? If yes, plz provide with some inputs..
07-05-2009 07:20 AM
As you have not specified I will assume that you are using CUCM rather than CUCM Express and that it is a relatively recent version.
You can use the Time of Day Routing facility described at the link below to control when partitions are available.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html#wp1044721
If you put your PSTN access route patterns into a partition and then apply a time schedule that only makes the partition available during working hours you will achieve what you need.
Please rate if helpful.
07-05-2009 07:36 AM
Thanks for your quick response....I will try this & update...
One more query: i want employees who wants to dial any outbound call has to login to the IP phone. If any user doesn't login to the Phone then he/she must not be able to make any outbound calls...Only inbound calling will be available....This i need in normal office hours as well...
Can this is done??
07-05-2009 08:07 AM
Yes, use EM for that purpose
java
if this helps, please rate
07-05-2009 09:11 AM
As Java stated you could do this using Extension Mobility (EM) as described at the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/cmapps.html#wp1043689
An alternative would be to use Forced Authorisation codes (FAC) which require a user to enter an authorization code to reach the intended recipient of the call.
When a user dials a number that is routed through a FAC-enabled route pattern, the system plays a tone that prompts for the authorization code. To complete the call, the user authorization code must meet or exceed the level of authorization that is specified to route the dialed number.
