NONE Softkey templete
Hello All,
Hope some one help me on this. What are the options I will get on the phone if I choose <NONE> in sfotkey templete in phone cofiguration page.
Thanks.
M
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Murali,
If you choose in the Softkey Template then you will
use the Softkey that is referenced in the Common device config
like below. In this case,
MigratedCommonProfile2
which uses the Standard user Softkey template
Common Device Configuration Information
Required Field
Required Field
Required Field
Required Field
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Hi Murali,
Required Field
Required Field
Required Field
Required Field
Cheers!
Rob
- Tom Petty
Thanks a lot Rob,
-M
224
