Normalization Script - Modifying INVITE
Hi guys,
I would have a question regarding the normalization scripts for SIP.
Is there a way to modify the second field in an INVITE request? (sip:DN@IP)
INVITE sip:7111@192.168.15.111:5060 SIP/2.0
Date: Mon, 28 Oct 2013 09:25:39 GMT
Call-Info: <sip:192.168.15.1:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Thanks a lot.
1 ACCEPTED SOLUTION
VIP Super Bronze
Yes you can chnage the request URI..
The script below changes the RURI from XXXX@211.211.211.211 to XXXX@Test.com
M = {}
function M.outbound_INVITE(msg)
local method, ruri, ver = msg:getRequestLine()
local uri = string.gsub (ruri, “211.211.211.211″, “Test.com”)
msg:setRequestUri(uri)
end
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Cristian,
It is possible to do using sip profiles.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080982499.shtml
Kind regards,
Andrew C.
Kind regards, Andrew C.
Hi Andrew,
thanks for the reply.
It works great using sip profiles.
But is there a way to do it on Call Manager with norm. scripts?
Thanks.
Sorry, I haven't noticed that you want to use normalization scripts. I've never used them, but it seems that yes, you can change almost everything using it.
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/unified-comm-application/blog/2012/03/12/modifying-sip-header-in-call-manager-sip-normalization
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/sip_tn/8_5_1/10-sip_transparency.html
Kind regards,
Andrew C.
or is there a way to force the Voice Gateway to route incoming invites based on the TO header instead of the request uri?
because the TO header can be easily modified with norm. scripts:
M = {}
    msg:removeHeader("To")
    msg:addHeader("To", "<7222>")
end
return M
Thanks.
Sorry, can't help with that, I have only theoretical knowledge regarding this question. Hope someone in community would be more helpful.
Kind regards,
Andrew C.
thanks Andrew.
It seems that you can modify nearly everything but I'm not really sure regarding the INVITE SIP-Req-URI...
Has anyone tried this?
Thanks.
VIP Super Bronze
Cristian,
First of all you can only use normalization scripts on CUCM. With voice gateways you only use sip profiles.
Second, you can only apply sip profiles in the outbound direction, you can use it to change headers in the outbound direction as far as the gateway is concerened.
Hi aokanlawon,
yes, that is clear.
The problem would be that I can't change the request uri using norm scripts on Call Manager.
Is there a way that I can access the request uri in the invite message using norm scripts (on Call Manager)?
Thanks.
VIP Super Bronze
M = {}
end
great. thanks.
it seems that it can be done with setRequestUri.
M = {}
    msg:setRequestUri("tel:1234")
end
return M
Thanks.
618
