Nortel PBX -- QSIG -- VG H.323 -- CUCM -- Cisco IP Phone / No name on Nortel side
I've read tens of threads about PBX and CUCM integration as far as calling/connected name and number are concerned without finding any solution.
As far as I'm concerned we're going from Nortel to Cisco. VG need H.323, not MGCP.
CUCM runs 8.6.2 , VG are running IOS 12.4(22)T5
Nortel PBX ---- QSIG ISGF ---- VG H.323 ---- CUCM ---- Cisco IP Phone
I've set as recommended in several threads
voice service voip
qsig decode
h323
  h225 display-ie ccm-compatible
interface Serial0/0/0:15
  isdn supp-service name calling profile Network-Extensions operation-value-tag local
On Cisco IP Phone I have the name and phone number of the Nortel phone for outgoing and incoming calls. So it's fine.
But on the Nortel side only the number is displayed when calling to or called by a Cisco phone.
From Cisco to Nortel
Aug 29 16:42:07: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 7116242
Aug 29 16:42:07: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0095 callID = 0x8016 switch = primary-qsig interface = User
Aug 29 16:42:07: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0095
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Facility i = 0x9FAA068001018201018B0100A1080201320201008000
        Calling Party Number i = 0x0081, '7116242'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '20'
Aug 29 16:42:08: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8095
Aug 29 16:42:08: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8095
        Facility i = 0x9FAA068001008201008B0100A111020201000201018008434F52414C20432E
        Progress Ind i = 0x8182 - Destination address is non-ISDN
Aug 29 16:42:10: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8095
        Facility i = 0x9FAA068001008201008B0100A111020201000201028008434F52414C20432E
        Connected Number i = 0x0080, '20'
Aug 29 16:42:10: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0095
Aug 29 16:43:02: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8095
        Cause i = 0x8190 - Normal call clearing
Aug 29 16:43:02: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0095
Aug 29 16:43:03: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8095
From Nortel to Nortel (normal behaviour with name and number)
5:19:25: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x4 0x9, Calling num 7003694
5:19:25: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0090 callID = 0x8011 switch = primary-qsig interface =
5:19:25: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0090
        Standard = CCITT
Facility i = 0x9FAA068001018201018B0100A11702012D020100800F4C4F43414C20464945204C414E4359
Facility i = 0x9FAA06800100820100A117020105020100800F4C4F43414C20464945204C414E4359
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x4980, '7003694'
        Plan:Private, Type:Subscriber(local)
Called Party Number i = 0xC9, '3030'
5:19:25: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8090
5:19:25: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8090
Facility i = 0x9FAA068001008201008B0100A11602020100020101800D464158205052494E434950414C
5:19:32: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8090
Facility i = 0x9FAA068001008201008B0100A11602020100020102800D464158205052494E434950414C
Connected Number i = 'i', 0x80, '70530'
5:19:32: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0090
5:19:37: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0090
Cause i = 0x8090 - Normal call clearing
5:19:37: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8090
5:19:37: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0090
Facility message is shorter with Cisco to Nortel call setup, and there's only 1 message compared to 2 facility message on a Nortel to Nortel call.
Is there something else I can try or there's no way with QSIG and H.323 vg with Nortel ?
JC
Everyone's tags (5)
1 REPLY
isdn outgoing display-ie  under interface Serial does not change anything.
Any other idea ?
JC
1077
