07-24-2013 11:07 AM - edited 03-16-2019 06:32 PM
HI ,
I am configuring 7961g sccp to sip firmware. I have version cmterm-7941_7961-sip.8-0-2SR1. But it is looking for CTLSEP_Mac.tlv file. I have tried another hirger firmware too but same issue. Even use different type of TFTP server.
Still phone is in Unprovisioned Stage.
Amardeep Rana
Solved! Go to Solution.
07-25-2013 07:03 AM
This isn't an Asterisk forum. The manual XML file editing you're attempting isn't needed with Cisco call agents so the people on this forum won't be practiced in it. A quick Google search turned this up though:
http://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79x1+xml+configuration+files+for+SIP
Good luck.
Please remember to rate helpful responses and identify helpful or correct answers.
07-24-2013 06:02 PM
The CTL file is used for mixed-mode clusters and is not relevent to your firmware; the phone always asks for it.
If the phone says "Unprovisioned" on it, you're running SIP.
07-25-2013 03:01 AM
Thank You Jonathan
Yes , phone says "Unprovisioned" on it and it is shwoing SIp firmwae also when I check it . But please let me know how to get it working. I want it working with Trixbox server.
ThankYou
Amardeep Rana
07-25-2013 07:03 AM
Good luck.
07-26-2013 09:05 AM
Thank You Jonathan,
You helped a lot.. I should mark it as Answer.
There was issue wth my Sepmac.cnf.xml . I make it proper and everthing is fine.
Amardeep Rana
