Not able to Convert 7961g SCCP to SIp
HI ,
I am configuring 7961g sccp to sip firmware. I have version cmterm-7941_7961-sip.8-0-2SR1. But it is looking for CTLSEP_Mac.tlv file. I have tried another hirger firmware too but same issue. Even use different type of TFTP server.
Still phone is in Unprovisioned Stage.
Amardeep Rana
1 ACCEPTED SOLUTION
VIP Super Bronze
This isn't an Asterisk forum. The manual XML file editing you're attempting isn't needed with Cisco call agents so the people on this forum won't be practiced in it. A quick Google search turned this up though:
http://www.voip-info.org/wiki/view/Asterisk+phone+cisco+79x1+xml+configuration+files+for+SIP
Good luck.
Please remember to rate helpful responses and identify helpful or correct answers.
VIP Super Bronze
The CTL file is used for mixed-mode clusters and is not relevent to your firmware; the phone always asks for it.
If the phone says "Unprovisioned" on it, you're running SIP.
Thank You Jonathan
Yes ,   phone says "Unprovisioned" on it and it is shwoing SIp firmwae also when I check it . But please let me know how to get it working.  I want it working with Trixbox server.
ThankYou
Amardeep Rana
VIP Super Bronze
Good luck.
Thank You Jonathan,
You helped a lot.. I should mark it as Answer.
There was issue wth my Sepmac.cnf.xml . I make it proper and everthing is fine.
Amardeep Rana
220
