NOT ABLE TO FIND Dial peers and gateway commands
Hi all,
I have 2951 router with "C2951-universalK9-mz-SPA.152-4.M3.bin" ios , my problem is that when I try to configure diap peers i am not seeing these command under "conf ter" , so any one have ide what is the probelem, please help me out for this issue.
I  hope i will receive solution with details .
Rizwan
Hi Rizwan, If you run a "show
Hi Rizwan,
If you run a "show version"  command. Can you see the UC license installed on your router?
Please rate helpful answers
Gabriel
hi Gabriel, Thanks for reply
hi Gabriel,
Thanks for reply , yes I am seening these info
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FTX1545A0QW
Technology Package License Information for Module:'c2951'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
You don't have a UC license
You don't have a UC license in order to configure voice related commands, you need to buy the license, install it, and then, you can configure DPs.
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Purple
Hi Rizwan, as rightly
Hi Rizwan,
as rightly mentioned by Jaime, u do not have Unified communications /UC license [+5].
you can generate en evaluation license and try the commands.At same time , go for permanent license.
regds,
aman
Bronze
Hi Rizwan,To activate the 60
Hi Rizwan,
To activate the 60-day evaluation license enter:
1. configure terminal
2. license accept end user agreement
you will find more details here:
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
thanks bro ,yes u r write ,
thanks bro ,yes u r write , thanks for response I have solve this issue as per ur advice
thanks bro , yes u r write ,
thanks bro , yes u r write , thanks for response I have solve this issue as per ur advice
181
