Community Member
not able to hear voice while conference
hi all,
I have ccm 6.1 and is configured with VG via H.323. i am having two problems
i) while making conference call between internal & pstn call, none of the participants are able to hear each other's voice, well On ip phone it shows connected !!!!
internal conference between ip phones is working fine.
ii) in Call Parking, after reteriving Parked call, both of the users are not able to hear each others voice ....Call Parking between ip phones (internally) is working fine.
in Call Manager Media Termination Point + Transcoder + Conference Bridge are registered, but still im having problem.my running config is attached.
Please check out my config & suggest where i am doing mistake.
thanks in advance,
Green
Re: not able to hear voice while conference
check IP Routing and sccp binding, make sure all voice networks and ip phones can reach proper VLan/network
Community Member
hi gogasca!
Thanks for your reply !!! all the phones are reachable to voice vlan !!! if there would be some ip routing issue, then i think i would have same problem for incoming calls also !!! but i m facing issue in conferencing and call parking !!!
any other suggestion !!!
Bronze
Hi, try adding the "voice rtp send-recv" command on your gateway.
Hope this help
David
144
