not able to login CCM 4
hi folks.
i have just restored the backup to callmanager and i am not able to login to it anymore.
Green
Re: not able to login CCM 4
which error u get?
IIS is running?
DId u use same IP and hostname?
You were using MLA ?
i am not getting any error.
when i login using the username and password its not allowing me.
i am on the server itself.
i restored the backup and wht i figured out is that i am not able to login though i was logging before restoring backup to freshly installed callmanager.
one issue can be that after restoring the username and password it might have been restored to previous one.
also the login to windows is a different usename and password then to callmanager.
thxx for your kind support
any help....
i am doin it for a customer.
185
