Not able to see speed dial on CCM Enduser page
                   Hi All
i have a user who is using the Cisco IP Phone 7962 and 7915 Expansion Module is associated with it.
Configuration is fine .
As i login to CCM Admin page and check the extension i can see all the speed dial but as i enabled the CCM END user page for the User, as user login to CCM END user page, user is not able to see the speed dial
I checked at end user roles are group have assigned to user and it has  the rights to read/write and update the speed dial and the device is associated with end user
Please suggest me how i can make it working.
Chaman
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Chaman,
Are you sure that the users can modify BLF-Speed Dials? Or are the other users
able modify "normal" Speed Dials? I would double check as this capability has been asked
about many times and is not currently possible
Unified CM Speed Dial Presence
Unified CM supports the ability for a speed dial to have presence   capabilities by means of a busy lamp field (BLF) speed dial. BLF speed   dials work as both a speed dial and a presence indicator. However, only  the system administrator can configure a BLF speed dial; a system user  is not allowed to configure a BLF speed dial.
From the CUCM 8.x SRND;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/presence.html#wp1084090
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
Hi Chaman,
The first place I would check would be under CUCM Enterprise Parameters>
CCMUser Parameters> = True
Cheers!
Rob
- Stones
Hi Rob
Thanks for Rplying
I checked in CUCM Enterprise Parameter>CCMUser Parameters> its true there
All the other user are able to see and modfiy the speed dial at CCM End user page
Till now i have only one user having  7915 expansion module . and he is not able to see the speed dial at END user page
once he login to CCM end user and click on Speed dial tab its shows nothing there ....all  Blank.
Chaman
Hi Chaman,
Just make sure that these are not BLF-Speed Dials as these
can only be modified via CUCM admin access.
Cheers!
Rob
- Stones
Hi Rob
These are BLF Speed dials
If these cannot be modified with the CCM End user page
So i am wondering whether user would be able to see the speed dial on CCM enduser or not???
As per my understanding user should  see the speed dial
And one more things, many other users are using Cisco 7962 Phone and they have 2 lines and rest 4 are BLF speed dial
and as they login to CCM end user page they can see and modiy the Speed dial as per their need.
How come it possible this impacted user is not able to see and modify BLF Speed dial?
Correct me if i am wrong
Chaman
Hi Chaman,
Cheers!
Rob
- Stones
Re: Not able to see speed dial on CCM Enduser page
Hi Rob
Thanks for your Help
I tested it at my end and found End user allow us to modify Speed Dial not BLF Speed Dial
Thankful to you to make my point clear on this and educate me
Chaman
Hi Chaman,
You are most welcome my friend
Cheers!
Rob
- Stones
605
