NOT ANSWERED: Change Cisco 7960 Language to FRENCH
My boss asked me to change the language on our Cisco 7960 SIP phones.
We do not use Cisco CallManager.
We use the latest Firmware in our phones.
We use FreePBX 12. Does it has anyone who knows how to add language on the Cisco 7960 phones ?
Thanks you very much for your answer.
1 ACCEPTED SOLUTION
I'm not familiar with FreePBX
I'm not familiar with FreePBX 12, but you should be able to access the phone's webpage and adjust the individual phone's locale from there.  From my understanding, you can also do it from the CLI in FreePBX 12.
Hi, Thanks you very much for
Is it a special way to access the phone webpage ?
Should I be able to access it on port 80 ?
On FreePBX, I never read I can access my phone webpage thru the CLI.
Do you have any other ideas ?
Thanks for your reply.
I meant phone locale should
I meant phone locale should be able to be changed through CLI in FreePBX.  To access a phone webpage, you will need to ensure the phone web access is enabled and then you will be able to access the phone via https://PHONEIP/index.html
And how can I ensure my web
And how can I ensure my web access is enable on the phone ?
How can I enable it without Cisco Callmanager ?
On Call Manager, you have the
On Call Manager, you have the option to enable it on the Phone Page. Not sure, if there is a similar option in FeeePBX as well but you can always check at the below community page that is for FreePBX.
http://community.freepbx.org/
Deepak
123
