Community Member
Not receiving fax on CME via VG202
I am not receiving fax on CME via VG 202, specially when sent from another CUCM via ATA device. It says "connection error" on the sender fax machine.
The VG202 config is as below:
Current configuration : 2129 bytes
version 12.4
no service pad
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711alaw
h323
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
  h225 timeout tcp establish 5
  h225 timeout connect 60
  h225 timeout call-proceeding 5
  h225 timeout setup 5
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
description DOWNLINK TO CISCO3750 SWITCH
ip address 172.24.130.5 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.24.130.5
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 172.24.130.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.24.130.1
no ip http server
control-plane
voice-port 0/0
voice-port 0/1
ccm-manager fax protocol cisco
ccm-manager sccp local FastEthernet0/0
dial-peer voice 1000 voip
description Outgoing Calls to CME
destination-pattern 9T
voice-class h323 1
session target ipv4:172.24.129.193
codec g711alaw
no vad
dial-peer voice 1001 voip
description Outgoing Calls from CME
voice-class h323 1
incoming called-number .
codec g711alaw
no vad
dial-peer voice 10 pots
description Incoming Calls to VG port
destination-pattern 899
port 0/0
forward-digits all
end
Am I missing something or is it something to do on the CUCM side ?
Please advice.
Binu
1 REPLY
Green
Binu,
Have you changed the settings on the ATA 186s to support FAX
Http://ATA IP ADD/
Look at
Audio Parameters ---> Audio Mode
For FAX on both ports
Re-write  to
0x00150015
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
811
