Notify all phones when main number is ringing
I'm wondering what the best way to configure this is.  we have a main number coming into an office at DN 8427.  We have a group of people who work after hours at their desk and want to answer the 8427 number when the attendant is not there.  (DN's 2721,2722,2723,etc)
If I put 8427 and 2721,2722,2723 in a pickup group, all the phones in that group are notified when each others phones are ringing.  I just want the 2721,2722,2723 DN's to be notified if the 8427 is ringing.
Thanks.
Start by mentioning what call control and version you use.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Call Manager  9.1.1.10000-11
I'd suggest a shared line for that, only when that DN is called, it will ring on all the other phones.
java
java
What if I don't have another line to put the shared line on?
Re: Notify all phones when main number is ringing
Hi.
Which model are those phones?
I can suggest, if the model is suitable,
a speed dial on each phone with blf and pickup option activated
Carlo
Please rate all helpful posts "The more you help the more you learn"
Check this helps,
1) Remove x8427 from attendant's phone and configure it as hunt pilot and configure 2721,2722,2723 in line group.
2) Configure a dummy ext(eg 1000) on attendant's phone but make sure Alerting name, display name, line text label are configured as 8427 and also make sure you have add the dummy ext in Hunt pilot 8427 as a 1st line.
DN configration:
DN -1000
Alerting name - 8427
display name - 8427
line text label - 8427
Hunt pilot - 8427
line group - 1000,2721,2722,2723
I gave this solution to many of the user its works well. But the disadvantage is, when attendan make internal calls, the other end person will recieve the caller ID as 1000(8427).
-Murali
Just an idea... I f you have CUC you can route the call to a System Call Handler and apply a schedule to it so that during normal working hours it only rings onto the attendant's phone. Then during out-of-hours you can configure it to transfer to a Hunt Group similar to what Murali had suggested above...
David
199
