Now for external calls
Hi all
I now have thanks to this these forums got  my call  manager 6 set-up (vmware) and able to make internal calls, I now wish to  try and go to the next stage of making external calls...
I have a  Cisco 2081 running c2801-ipvoicek9-mz.124-11.T2 with the following  Hardware: -
4 Voice FXO Interfaces
3 DSPs, 48 Voice Resources
1  Cisco Service Engine
This used to be used as a CCME but I would  like to use it as my Voice Gateway, problem is I'm not sure which route  to take; SCCP or MGCP and I'm hoping you could point in the correct  direction for the Router I'm using.
Thanks all
Martyn
2 ACCEPTED SOLUTIONS
Re: Now for external calls
For a PSTN gateway, I prefer MGCP but you'd typically go with MGCP or H323 for that.
Hailey
Well, you wouldn't use SCCP for the gateway (except for any conferencing/transcoding resources you have). You would likely use MGCP or H.323. Since you are learning you could try both and figure out which one you would like to use.
mgcp config guide: http://www.cisco.com/en/US/docs/ios/voice/mgcp/configuration/guide/12_4t/vm_12_4t_book.html
h323 config guide: http://www.cisco.com/en/US/docs/ios/voice/h323/configuration/guide/vh_h323_gwconfig_ps6441_TSD_Products_Configuration_Guide_Chapter.html
cucm gateway config guide: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b06gtway.html
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hailey
HTH.
Bill
Thanks both for your swift replies, plenty of reading for me to do.
Martyn
176
