Community Member
NTP CCM 4.1 Issue
Phones doesn't display right time. How can I fix it? Found links from forum, but they doesnt work.
Help,please
VIP Super Bronze
Re: NTP CCM 4.1 Issue
Phones get their time from the Time Group configured in the device pools. Have you configured the right time there?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
Is the server displaying the right time?
Follow this link to sync CM with NTP:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009470f.shtml
HTH, please rate all useful posts!
Chris
Community Member
I follow the link, but when i try to use de ntpdate command the following message appear:
C:\>ntpdate 10.8.1.50
'ntpdate' is not recognized as an internal or external command,
operable program or batch file.
C:\>
what can I do?
THanks in advance,
Gustavo
I usually follow the steps below and seems to work very good.
1. Go to \Winnt\System32\drivers\etc
2. Open ntp.conf in Notepad
3. Modify the file/content in their to reflect the NTP Server IP address.
For e.g 172.18.106.15 is my NTP Server
server 172.18.106.15 # Set Local Clock to Authoritive Time Source
fudge 172.18.106.15 stratum 5 # Resets Stratum from default 3 to 5
driftfile C:\WINNT\system32\drivers\etc\ntp.drift # path for drift file
4. Go and now stop the Network Time Protocol Service
5. If you want you can now change the time on the box to hour ahead or back, to test if NTP will work or not.
6. Open command prompt and go to \Program Files\Cisco\Xntp
7. Type the command "ntpdate x.x.x.x" - Where x.x.x.x is the NTP server IP address.
C:\Program Files\Cisco\Xntp>ntpdate 172.18.106.15
Looking for host 172.18.106.15 and service ntp
host found : vnt-ntp.cisco.com
29 Sep 14:57:51 ntpdate[924]: step time server 172.18.106.15 offset -10719.468824 sec
8. The NTP will update the clock/date, etc on the server and then should come back to the prompt again.
9. Go back and start the Network Time Protocol Service.
As you can see you do not type ntpdate on the root.
Hall of Fame Super Red
Hi Jorge,
As always, an extremely high quality answer from you! +5 points for your continued great work here.
Take care,
Rob
219
