NTP in CM not work
Hi All,
I tried to config NTP in my CM 4.1(3) in W2k server, from the debug, seems the NTP is running, but the time of NTP server (my router) and the CM can not be the same. My router is 192.168.100.11 and my CM is 192.168.100.200. In the test I change my router's clock to Jan 2006. CM's clock is Sep 2007.And the following is the debug. Where is the problem?
Jan 1 12:48:01.279: NTP: rcv packet from 192.168.100.200 to 192.168.100.11 on F
astEthernet1/0:
Jan 1 12:48:01.283: leap 3, mode 3, version 4, stratum 0, ppoll 256
Jan 1 12:48:01.287: rtdel 0000 (0.000), rtdsp 00FC (3.845), refid 494E4954 (73
.78.73.84)
Jan 1 12:48:01.287: ref 00000000.00000000 (08:00:00.000 fake Mon Jan 1 1900)
Jan 1 12:48:01.291: org C7624DBE.FCEDBCB8 (20:46:54.988 fake Sun Jan 1 2006)
Jan 1 12:48:01.291: rec CA8DF8DC.94622F34 (12:45:16.579 fake Sun Sep 9 2007)
Jan 1 12:48:01.295: xmt CA8DF95C.787756E4 (12:47:24.470 fake Sun Sep 9 2007)
Jan 1 12:48:01.295: inp C7624E01.47A4999E (20:48:01.279 fake Sun Jan 1 2006)
Jan 1 12:48:01.299: NTP: stateless xmit packet to 192.168.100.200:
Jan 1 12:48:01.303: leap 0, mode 4, version 4, stratum 1, ppoll 256
Jan 1 12:48:01.303: rtdel 0000 (0.000), rtdsp 0002 (0.031), refid 4C4F434C (76
.79.67.76)
Jan 1 12:48:01.307: ref C7624DC1.B745235E (20:46:57.715 fake Sun Jan 1 2006)
Jan 1 12:48:01.307: org CA8DF95C.787756E4 (12:47:24.470 fake Sun Sep 9 2007)
Jan 1 12:48:01.311: rec C7624E01.47A4999E (20:48:01.279 fake Sun Jan 1 2006)
Jan 1 12:48:01.315: xmt C7624E01.4BD7EF74 (20:48:01.296 fake Sun Jan 1 2006)
Thanks!
Best Regards,
Teru Lei
Re: NTP in CM not work
Hi Teru,
Not sure how you configured, here's some info just to share how NTP is configured in CCM.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008009470f.shtml
I am using the same method to configure my ccm and the NTP works fine.
I just have a the following in my CM1 ntp.conf:
Server 1.1.1.1
Server 1.1.1.2
driftfile C:\WINNT\system32\drivers\etc\ntp.drift # path for drift file
My CCM Publisher points to the NTP servers and the CCM Subscribers point to the Pub for synchronization.
HTH,
Eugene
I just met somebody with the same problem. I used the same way as you and the problem should be that W2k need long time to sync with NTP server. the larger time difference between W2k and NTP server, the longer time needed to sync the server with NTP server. My time difference is around 1 year, so...
I need time to try again to see the result...
Teru Lei
99
