NTP ISSUE in Callmanager
Dear All ,
I have some issue in NTP Settings in my CallManager ,I have different NTP server for different countries and this NTP are configured for Different Call Searching Space .But now i am getting the Same NTP time in all call Searching Space .Can any one provie me the solution.
2 ACCEPTED SOLUTIONS
Mate,
You dont need to point to different NTP servers (NTP reference) for different locations, you will need to define different Date/Time groups for each DEVICE POOL, dependent on the Timezone of each location.
if you have different devicepools using different NTP references, but the same Date Time group, well since all NTP servers are UTC, you will have the same time on all your phones. The Offset makes the difference!!
regards
Please remember to rate useful posts, by clicking on the stars below.
And you are using different timezones in each Date Time group, so your time group for for instance Paris, has the Paris Timezeon (GMT +1) ?
Mate,
regards
Dear Minkdennis ,
I had Different devicepools and Different Date Time Group ,but still the same issue is exist ....is there any other way to solve this issue ....waiting 4r your reply ....
Thanks.,
275
