NTP master/peer
going through the CCIE LAB, i see sometimes used ntp master and others ntp peer, i looked into the command lookup but could not figure out!!!!
Any one knows the difference?
on the other hand do we need something else on the router to make it as ntp master, like startum...
Good day
Re: NTP master/peer
The NTP master command lets the NTP on the other device (ntp peer) to sync to the current node. A node could at the smae time serve time to many nodes and at the same time get synced to the many NTP masters.
Re: NTP master/peer
Hi again,
i am confused, let us take the example below:
Router A: NTP Master
Router B, C and D: NTP peer; those will be servicing other clients, IP Phones for instance.
1)is this right?
2) how can we have multiple ntp masters!!!
Good day
Re: NTP master/peer
NTP master will set up the router to respond to NTP time requests for peer devices. All you need to do is is configure NTP master on one router and set the clock -
UC520.120#conf t
Enter configuration commands, one per line. End with CNTL/Z.
UC520.120(config)#
UC520.120(config)#
UC520.120(config)#
UC520.120(config)#ntp master
UC520.120(config)#
UC520.120(config)#exit
UC520.120#
UC520.120#clock set 23:00:00 18 Feb 2008
UC520.120#
UC520.120#exit
UC520.120#sh ntp ?
associations NTP associations
status NTP status
UC520.120#sh ntp stat
Clock is synchronized, stratum 8, reference is 127.127.7.1
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18
reference time is CB63F54B.301CAAE6 (23:15:07.187 AEST Mon Feb 18 2008)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.02 msec, peer dispersion is 0.02 msec
UC520.120#
[Resuming connection 1 to 10.66.75.55 ... ]
on the peer router -
ntp peer 10.66.75.120
CWD.19.07-2800-3#
CWD.19.07-2800-3#sh ntp stat
Clock is synchronized, stratum 9, reference is 10.66.75.120
nominal freq is 250.0000 Hz, actual freq is 250.0002 Hz, precision is 2**18
reference time is CB63F55D.8D948760 (12:15:25.553 UTC Mon Feb 18 2008)
clock offset is -8.0557 msec, root delay is 2.11 msec
root dispersion is 9.57 msec, peer dispersion is 1.48 msec
CWD.19.07-2800-3#
All other devices peer off the master. So every peer device in the network points to the master reference.
Re: NTP master/peer
thanks a lot for your help, what i understand is the following:
ntp master: (it will be the server giving the time to the peers)
ntp peer ipntpmaster
ntp server ipntpmaster
In such case what is the difference between the ntp peer and ntp server (i have read somewhere that with one of them it acts as a master as well!!!)
please advice
Good day
Silver
Re: NTP master/peer
pcameron - what if the master is configured to source time from the internet?, i.e. the 'clock set' command is not used. If this device i.e. master fails to source time - will it continue to service time requests received from it's peers?
Ajaz
425
