Community Member
NTP Server ccm 5.1.1
Hey All,
I'm just pre planning for a day lights saving time change in a voice environment. I'm curious, if the NTP server is set in a call manager cluster, are the end phones time dependent on the NTP servers time? or does a update need to be installed on the ccm?
Many Thanks,
a
Community Member
Re: NTP Server ccm 5.1.1
No Update required ,You can eneble DST on ccm 5.1.1
DST patch avilbale for only
CSCse96035
Callmanagers do not have all timezones included in Date/Time Group Info
CSCsg85605
Need support for introduction of Western Australian Daylight Savings Info
CSCsh15176
Daylight saving does not work for non-TNP phones, Australia Info
CSCsh71430
Timezones in TypeTimeZone.csv have errors. Info
CSCsj56299
CDR Analysis and Reporting does not reflect DST changes for New Zealand
HTH ,Pls rate it
Community Member
hello,
Thanks for your reply.
Day lights saving time has changed in au. So my concern is the time wont change on end user phones.
I'm thinking the times from the phones is received from the NTP servers configured in OS configuration?
Community Member
Need to reset the IP Phones.
For testing reset one phone and check the status
HTH * Pls rate it*
Community Member
What information in the status of the phone is useful in regards to NTP server from the ccm cluster?
133
