NTP setup for CCMs and Unity
Hi All
I did the procedure showed bellow for a cluster with 2 CCMs, where I dont change nothing for the Suscriber becuase it is pointing to the Publisher who is now working with the NTP. I restarted the NTP service on the SUB but I dont see that it is taking the time from PUB
It is that contain the ntp.conf file of the Subscriber:
server PUBHLISHER1 # Hostname of Primay CallManager
driftfile C:\WINNT\system32\drivers\etc\ntp.drift # path for drift file
Procedure utilized:
Complete these steps in order to verify that the NetworkTimeProtocol service is configured to
launch automatically upon start-up:
a. Right-click on My Computer and select Manage.
b. Expand the Services and Applications section.
c. Select Services.
d. Double-click on the Network Time Protocol service.
e. Ensure that Start-up Type is set to Automatic.
1.
Configure the C:\WINNT\system32\drivers\etc\ntp.conf file.
This file contains the list of Time Servers that Cisco CallManager becomes synchronized with. You
can configure Cisco CallManager to point to specific Time Servers, or you can configure it to receive
NTP broadcasts on the local LAN segment from the router (as long as the router is configured to do
so).
Sample ntp.conf file that uses static Time Servers:
à server 10.0.0.10
à server 10.1.0.10
à driftfile %windir%\
In the Unity, I could find the ntp.conf file, do you know where I have to set up the NTP?
Pls your coments
1 REPLY
Silver
Re: NTP setup for CCMs and Unity
Unity the time syncs with the Domain controller.
option 2
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009470f.shtml#procedure4
hope this helps
Randy
327
