NUM-EXP DOES NOT WORK
hi good day
I have configured a num-exp however I see that are not working properly ie the call does not end at ext indicated that tagging tries to send the last dialed numbers
call his voice brief  I see the term 8100 call and tries to look at the CUCM that ext does not exist instead of sending the call to ext 9840 indicated
could help
num-exp XXXX810. 9840
num-exp XXXX811. 9840
num-exp XXXX812. 9840
dial-peer voice 1000 voip
 description *** DP a Callmanager ***
 preference 1
 destination-pattern [1-9]...T
 session target ipv4:10.X.X.2
 dtmf-relay h245-alphanumeric
 codec g729r8 bytes 40
 ip qos dscp ef signaling
 no vad
1 REPLY
Can you post a "show run"
Can you post a "show run" from your gateway ? Also, what is the call flow ?
Nipun
36
