Number cut off on CME
Hi all,
when receive a fax from a number of a customer my cme cut same digits.
For example when receive fax from 271090935 to 331755511, the CME cut two final digits 11 and route a call to internal 01.
This strange event occurs only on some numbers not all incoming fax.
I attached debug of a trace.
Below are some parts of the configuration:
dial-peer voice 101 pots
translation-profile outgoing OUTGOING
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
voice-port 0/0/0:15
input gain -2
echo-cancel coverage 32
cptone IT
bearer-cap Speech
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 1000
isdn incoming-voice voice
isdn send-alerting
isdn negotiate-bchan
no cdp enable
voice translation-rule 101
rule 2 /^\(...\)$/ /03317555\1/
voice translation-profile OUTGOING
translate calling 101
num-exp 331755501.. ..
num-exp 331755501... ...
num-exp 3317555.. ..
num-exp 3317555 01
Anyone help me please?
Thanks in advance.
M
Everyone's tags (5)
1 ACCEPTED SOLUTION
Re: Number cut off on CME
Hi Marco.
Found the issue... remove direct-inward dial from dialpeer 101
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Marco.
Can you try to modify your T302 value to 5000?
Carlo
Hi Carlo,
i changed value to 5000 but i have same issue.
Hi Marco,
     You have a number expansion command configured :
num-exp 3317555 01
A num-expansion acts before an outbound dial-peer is matched. I havnt had a look at the debugs yet, but that might be kicking in. Although the CME should do a Digit Analysis for the entire digit dialed, which is :
331755511
I shall go over the debugs and let you know, but as a test, is it possible for you to remove that and try a call?
Jagpreet
Hi Jaqpreet,
in the past i tried to delete "num-exp 3317555 01" but i had other issue...i could not reach any phone number on that site.
Marco,
     I understand. I shouldve looked at the debug before replying. Could you also please collect "deb isdn q931" along with "deb voice ccapi inout" and make another test call and share the same?
Jagpreet
Jagpreet,
i collect logs without "num-exp 3317555 01"?
No, with it would be just fine. I dont think thats the issue. Right now, in the initial Digit Analysis, CME does not read the "11". If it were the Num-Expansion, that would kick in after this.
I just want to make sure the incoming digits are good from the PSTN.
Jagpreet
Jagpreet,
attched debugs required.
p.s. there are 2 tabs on file .xls
Let me know.
Thanks.
Marco,
     In the incoming SETUP message from the PSTN, I see the called numbr as :
'3317555'
If we are dialing the correct number, then this is something you should contact the service provider about.
Jagpreet
Please rate helpful posts.
Jagpreet,
yes correct number that i compose is 331755511, but if i call this number from mobile phone it works fine.
What I will ask the provider?
Thanks.
M
Marco,
     Show them the incoming SETUP message from the debug and ask them whats going on.
Jagpreet
Marco,
You could try something like this to ensure that you "wait" for the overlap digits before hitting your number expansions.
voice translation-rule 100
rule 1 /^3317555\(..*\)$/ /\1/
voice translation-profile INCOMING
translate called 100
voice-port 0/0/0:15
translation-profile incoming INCOMING
It might also be possible to expand the voice translation-rule above so you don't need to use the number expansions.
Phil
Hi phershaw,
can i try your suggestion, but i must delete my "translation-rule 101" or can i add it without delete?
@Jagpreet Thanks!
Thanks.
Marco
Hi Marco.
Yes you can add it as rule 2 in your translation-rule 101
Carlo
Hi Carlo,
i added on my config and debug again but i see always Called Number=3317555 without 11 digits.
Thanks.
M
Marco.
If a call from mobile works fine and from fixed line not, this usually is a T302 or ISDN overlap issue.
While Mobile phones sends digits in en-bloc mode , fixed line do not, that's why I suggested you to modify T302 timer.
Another issue in your config is that you are missing "incoming called-number" part. to match incoming call (your gateway is matching dial-peer 100 for incoming).
So...
Please add the following dial-peer
dial-peer voice 200 pots
incoming called-number  33175T
direct-inward-dial
Try it and should work.
Carlo
Hi Carlo,
thanks again for reply.
I added in config;
voice-port 0/0/0:15
input gain -2
cptone IT
bearer-cap Speech
direct-inward-dial
port 0/0/0:15
maybe I'm wrong something but does not work.
Thanks.
M
Hi Marco.
Please add the dialpeer 200 I suggested and not in the outgoing dial-peer (please remove it from that) and add translation-profile incoming INCOMING on DP 200
Also activate debug isdn q931 and debug voip dialpeer inout and post here.
Carlo
Hi Carlo,
attached new debug and now it works with digit 11 and match DP 200.
But with this config can i do now outgoing call?
Thanks.
M
Hi Marco
Sure you can
Please remember to rate all helpful posts and mark as answered when you issue is solved
Carlo
Hi Carlo,
i try again and now and not works, below important parts of configuration is running:
no ip address
encapsulation hdlc
isdn overlap-receiving T302 5000
isdn send-alerting
no cdp enable
voice-port 0/0/0:15
input gain -2
cptone IT
bearer-cap Speech
direct-inward-dial
port 0/0/0:15
direct-inward-dial
num-exp 3317555 01
Hi Marco
can you please activate debug isdn q931 and debug voip dialpeer inout during a failing call and post here?
Carlo
Hi Carlo,
attached new debug for a failing call.
Thanks.
M
Hi Marco.
I also asked a debug isdn q931.
Carlo
Hi Carlo,
see the tab of excel file :-)
Thanks.
Marco.
Hi Marco.
Carlo
Hi Carlo,
i deleted "direct-inward" on DP 101 debugged call and works fine....tomorrow will test direclty in office (now i tested on remote).
If I understand correctly now there are 2 DP: 101 for outgoing call from internal to external and 200 for incoming call from external to internal. Now DP 200 match "translation-rule 100".
I did not understand what I did wrong, with original configuration wih only "dial-peer voice 101 pots" could not work?
Thanks.
M
Hi Marco.
Correct, DP 101 is for outgoing and 200 for incoming calls.
The problem was that calls was matching DP 101 because of the direct-inward dial. The vg tried to match first sent digits
3317555 without waiting for further digits and 3317555 was matched and calls were sent to 01 destination
Now, matching DP 200 and incoming called-number 33175T VG waits for further digits.
Hope this explanation would help you.
Carlo
Hi Carlo,
sorry for delay. I tested and works fine now.
Thanks a lot for support.
MM
965
