number of calls on one phones
hi we have a ccme router 3800
i want to assaign the operator phone one extension (pilot number) and atleast 8 to 10 calls should land on this extension without busy signal.i can get two calls by assaigning it to dual line but not more than that is it possible if yes thn pls help me out . thx for your consideration.
Hall of Fame Super Silver
Re: number of calls on one phones
With CME 2 calls per DN is the max. What you can do is create an overlay extensions, and do call forward to the overlay DNs. All of these DNs can be assign to the same button, such as.
ephone-dn 1 dual-line
number 1000
call-forward busy 1002
ephone-dn 2 dual-line
number 1002
call-forward busy 1003
ephone-dn 3 dual-line
number 1003
call-forward busy 1004
ephone 1
button 1o1,2,3,4,5
HTH, please rate all posts!
Chris
thx dude it was nice ....
but need one more clearence can i use this way also...
ephone-dn 10
number 1000
no huntstop
ephone-dn 20
number 1000
preference 1
ephone 3
button 1:10 2:20
thx for ur consideration..
sure, or you could also do
ephone 3
button 1o10,20
the only difference will be that the call will come in on the same line instead of the second line.
Chris
thx again but will post resolved once i will work tomm. on this
again regards & thx...
134
