Community Member
Number of users supported on a 29xx gateway
Hello everybody
I have a IP Telephony deployment with 700 users. I have a branch office with 40 users, which is the Gateway required for this site if I have to cover 50% with SRST. Do I have to use the 2911 which support up to 50 SRST or do I have to use the 2905 which support up to 35 SRST? what happen with the 50% of the users which don't need SRST, do they count in the ISRG2 capacity?
regards
1 ACCEPTED SOLUTION
Use the one that fits your user base and calculations, users who won't have a SRST reference are not considered, just the ones who will register with SRST.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
1-For SRST:
A-Your registered gateway , should be attached to RG "route group".
B-On device pool , assign route group for the router which will be used as SRST.
C-On device pool , SRST select "use default gateway". and do monitor for 30.
All phones which have the DP will be reregister your SRST router , this will be debend on the SRST license on your gateway and (max-dn & max-ephones) which are configured on your gateway.
Cisco 2901 Integrated Services Router
Up to 35 phones
Up to 35 phones
FL-CME-SRST-5=, FL-CME-SRST-25=, FL-CME-SRST-100=
Cisco 2911 Integrated Services Router
Up to 50 phones
Up to 50 phones
Cisco 2921 Integrated Services Router
Up to 100 phones
Up to 100 phones
Cisco 2951 Integrated Services Router
Up to 250 phones
Up to 150 phones
Cisco 3925 Integrated Services Router
Up to 730 phones
Up to 250 phones
Cisco 3945 Integrated Services Router
Up to 1200 phones
Up to 350 phones
Cisco 3925E Integrated Services Router
Up to 1350 phones
Up to 400 phones
Cisco 3945E Integrated Services Router
Up to 1500 phones
Up to 450 phones
Thank you
Please rate all useful information
Islam (+5)
Cisco Unified Survivable Remote Site Telephony
Compatibility Information
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_device_support_tables_list.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
174
