Number Restricted
hello  everyone
How to set up a few branches when  connecting to other internal extensions do not appear on the screen of  the number receiving the call?
Can I put  limited number or another number for anyone to call back
any help will be appreciated
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
1 ACCEPTED SOLUTION
Re: Number Restricted
Then your configuration is wrong at some place, the procedure outlined does work
Original DN cannot reach destination DN via CSS
Original DN reaches TP which blocks ANI.
TP CSS reaches destination TP.
Most likely your error is in CSS and partitions, review your configuration.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I'll assume this is CUCM so read this:
Call Display Restrictions
java
java
I read  and any questions I post
I followed the  procedures but did not work
I created the CSS  and the Partition restricted. Configured not to  display the extension number on the screen.
This  partition must access all branches but the other branches belonging to  domestic participants can not call these extensions.
java
java
176
