Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Number translation according calling type
We want to implement one translation rule to add prefix to the calling number when Cisco 2610 receives any incoming call with "International" ISDN number type.
For example, I deployed Cisco 2610 in China and International Access Code in China is "00".
If Cisco 2610 receives international incoming call from Japan as the following:
Calling Number: 8033386302
Called Number: 52589788
Number Type: International
I would like Cisco 2610 can add prefix "00" to the incoming calling number as the following:
Calling Number: 008033386302
Is it possible to do this in Cisco 2610?
Any help will be appreciated.
Bronze
Re: Number translation according calling type
Yes you can do this. In the example I have configured below, anything that starts with 803 will have 00 prepended to the number.
voice translation-rule 1
rule 1 /^803\(.*\)/ /00803\1/
cisco#test voice translation-rule 1 8033386302
Matched with rule 1
Original number: 8033386302 Translated number: 008033386302
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
Thanks for your reply!
But your solution is to translate the incoming calling number according to calling number pattern. In your case, you make translation from the case that incoming number is "00803xxxxxxxxxxxxxxx"
However, what we expect is to translate the incoming calling number according to calling number Type (International) instead of "calling number pattern"
Bronze
Have you checked out the following link to see if it would help?
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#type_plan
153
