Number unobtainable via a QSIG link between Cisco and Siemens...
ictnetworks
I am using CM 7.0 with a QSIG to a Siemens Realitis I have a problem with user busy status in the hybrid environment, when a Cisco phone calls a Siemens phone whilst it is in use you get engaged tone as expected, however the reverse gives number unobtainable. I have completed a debug isdn q931 below -
Cisco to Siemens
Aug 17 13:04:15.268: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x6E77
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x91AA06800100820100A11602010006042B0C0900800B4A616D6573204E6F626273
Calling Party Number i = 0x0081, '3533'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '7004909'
Aug 17 13:04:15.384: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xEE77
DEVG01#
Aug 17 13:04:15.620: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xEE77
Cause i = 0x8191 - User busy
Aug 17 13:04:15.660: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x6E77
Aug 17 13:04:15.788: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xEE77
Siemens to Cisco
Aug 17 13:04:52.304: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5174
Standard = CCITT
Channel ID i = 0xA18381
Preferred, Channel 1
Calling Party Number i = 0x0083, '7004909'
Called Party Number i = 0x80, '3589'
Low Layer Compat i = 0x8090A3
Locking Shift to Codeset 4
Codeset 4 IE 0x31 i = 0x82
Locking Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
DEVG01#
Aug 17 13:04:52.316: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xD174
Aug 17 13:04:52.524: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xD174
Facility i = 0x91AA06800100820100A11502010306042B0C0903800A4D61726B204172626F6E
Aug 17 13:04:52.712: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x5174
Cause i = 0x81E31C - Information element not implemented
Aug 17 13:04:52.740: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xD174
Any ideas would be gratefully received.
James
paolo bevilacqua
Cisco dis disconnecting by user busy;
Then PBX complains about that IE, that should not affect the fact Cisco has disconnected correctly, however yuo can prevent the cisco to sen facility IE under interface "no isdn ie outgoig facility".
Tried it still didnt work..
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no isdn outgoing ie facility
no cdp enable
The isdn q931 debug output
*Aug 19 15:32:23: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0028
Standard = CCITT
Calling Party Number i = 0x00A3, '5808'
Called Party Number i = 0x80, '7771'
Codeset 4 IE 0x31 i = 0x80
ocgr22#
*Aug 19 15:32:23: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8028
*Aug 19 15:32:23: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8028
Facility i = 0x9FAA06800100820100A1080201030201038400
*Aug 19 15:32:23: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0028
*Aug 19 15:32:23: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8028
ocgr22#
