Numbering plan
Hi all,
How can i configure 2 dial patterns 1. will look like 038xxxxxx which will forward 9 digits. The first one works fine but how can i configure second one that starts with 038 but can forward more than 9 digits. I am trying to do this with CCM6.1
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Numbering plan
what is the issue here? Simply create the additional pattern you want with the correct number of digits.
Re: Numbering plan
Re: Numbering plan
Thnx for reply i was confused because i used one dial pattern with NANP this was the reason that my second dial pattern didn't work.
115
