Numbers of Conference
Where I can see the numbers of the MeetMe conference o Ad-Hoc conference in the Cisco Call Manager ?
Re: Numbers of Conference
go to the CUCM service parameters for those values, look ad-hoc and unicast meet-me
128/ those numbers is the # of conferences
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
The question is: How can I determine the number of conferences held in a given month? For example, 34 conferences in January. Not the maximum amount of conferences supported by the server.
Hi friend,
You can check the Call Detail Records. May be you can read about this:
Call Detail Record Definition:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cdr_defs/4_x/cdr421.html
Hope this helps a little bit.
- Adrián.
Thanks, but you know how configure the CDR in the cisco call manager 6.0?
142
