Off-net Forwarding of inbound calls
We have a DID number that we need to transfer to an off-net location. What is the best method to accomplish this.
Re: Off-net Forwarding of inbound calls
configure a translation pattern on CUCM to reroute the call
java
if this helps, please rate
java
www.cisco.com/go/pdi
how would I configure it, do you have an example.
they're pretty straightforward
Translation Pattern -> your DID
Called party transform mask -> to where you want to send the call
just make sure the inbound CSS from your GW has the partition from the translation pattern and the CSS from the translation pattern can reach the route pattern you're going to use.
make sure called party has whatever is needed to make the call ie 9 for outside calls
java
java
Hall of Fame Super Gold
What about configuring CFA on a DN.
I didn't want to terminated on a phone
You don't need to put a phone, just the profile and CFA from http interface.
170
