off-net-on-net-off-net Calls failing
An issue occurs when an off-net call, from either a mobile VPN user or a user on another PBX connected to the UCM here in the UK - calls a device on another UCM (connected via ICT) that is call forward always to an offnet number. I have looked at the CSS & Partitions and they seem to be correct and DNA shows that the call should route but the call fails to NU tone. The call is successful if the originating device is a CCM user…..Block off=-net to Off net is FALSE on both UCM. One is 5.1 - the other 6.1...any ideas?
Silver
Re: off-net-on-net-off-net Calls failing
Post show version and show run from the gateway
As requested - hope you can help.
Attached
125
