OFF-Ramp Fax and Dial-Peers
hi,
can someone help me with the following problem:
I configured OFF-Ramp fax. I can send a fax as e-mail from Outlook client to the gateway and it deliver right as fax to the receiver via PSTN.
I use FAX=0030123456@faxgateway.domain.local as mail address.
I use a mmoip-dial-peer with incoming called-number 0. and a pots dial-peer for outgoing with destination-pattern 0.
This works fine.
Now I created a mmoip-dial peer with incoming called-number 49. and a pots dial-peer for outgoing with destination-pattern 49. for user how want to use
FAX=+4930123456@faxgateway.domain.local as mail address. Add Prefix 0 to present right number to provider.
But this didnt work. The debug dial-peer command show right the incoming mmoip peer with 49. , but then for outgoing no match.
Here are the peer configuration that didnt work.
dial-peer voice 7000 mmoip
description Offramp Fax incoming from Clients
service offramp-app
information-type fax
dial-peer voice 7001 pots
description Offramp Fax to PSTN
preference 7
prefix 0
port 0/0/0
dial-peer voice 7002 pots
preference 8
prefix 0
port 0/0/1
and this is the configuration works:
dial-peer voice 1000 mmoip
service offramp-app
dial-peer voice 1001 pots
preference 3
port 0/0/0
dial-peer voice 1002 pots
preference 4
port 0/0/1
1121
